LCA – Displaying the count inside ring using GQI query
Solved1.81K views18th April 2025GQI GQI queries LCA LCA Editor ring
Baranisudha Murugesan [DevOps Member]1.19K 29th October 2024 2 Comments
Im working on displaying the alarm count based on severity in a ring format in LCA. I have a GQI query to fetch the alarm count. but the ring control doesnt display the data from queries. Do we have any alternative way to display the alarm count in LCA inside a circle as shown in below image?
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th January 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 29th October 2024 0 Comments
Hi Baranisudha,
You can achieve this by using a grid component (see docs). In your template, include one layer for the circle geometry and another for the text. Use text interpolation to access the column value for the current row. Depending on your data structure—whether you have one row with a column for each severity level, or one row per severity—you’ll either create a template with four circles or a single circle.
Wout Mahieu [SLC] [DevOps Catalyst]12.31K Posted 29th October 2024 0 Comments
Hi Baranisudha
You can achieve this result using a grid component to display the different alarm counts. The template editor then allows you to configure custom templates based on your data for each row that is returned from the query. Here is what I was able to achieve in a few minutes.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 29th October 2024
