Kata#4 | How to apply interval and All Aggregate functions using GQI
Solved2.17K views19th January 2024Dashboard GQI GQI Filter
Vikas Choudhary [DevOps Member]576 27th October 2023 0 Comments
Dear Dojo Community,
If we are getting time series data, let's take an example, we are getting data in every 1 second.
We build a dashboard with timestamp filter. We build a query using GQI and it's fetching total counts or number of request records for the particular selected time range. It's working fine.
Now on top of that we want to give a functionality to select aggregate function (sum/min/max/avg/count) and period. how we can do that?
for example :- if user selected MAX and period 5 minutes and date range 24 hours, so query should fetch all 24 hours data for 5-5 mins interval. And 5 minutes interval will have max value during 5 mins.
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th January 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.66K Posted 29th October 2023 1 Comment
Hi Vikas,
As Sebastiaan mentioned, this option is currently not available. A possible workaround at this moment is to either the change the polling time of the parameter in the driver or update the timer base to reduce the polling frequency (Changing the polling speed of an element).
Hope it helps.
Vikas Choudhary [DevOps Member] Posted new comment 30th October 2023
Vikas Choudhary [DevOps Member] commented 30th October 2023
Thank you Miguel for the workaround but it’ll work if we have single user or sliding window configured from backend. Here we want to give option to user to aggregate data for particular sliding window and Dashboard/app can be accessible by multiple users. Everyone can filter base on their need. Few of them can see 5 mins sliding window data others can see 10 mins and so on. but minimum sliding window will be 1 mins as we are getting from hardware for every 1 mins.
Thank you
