Issues installing Visual Studio 2022 Templates
Solved1.15K views27th June 2025DataMiner Integration Studio Templates Visual Studio
Stephen Goode [DevOps Advocate]138 8th November 2024 6 Comments
i am experiencing issues trying to retrieve templates via DIS - have tried uninstalling and reinstalling the extension, any suggestions on how to resolve this ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Davor Joleski [DevOps Enabler] commented 11th November 2024
Could you check if you have the latest version of Visual Studio 2022?
if that can't help try with Vis 2019
if you in rush to try Vis 2019,otherwise i think is bug and It looks like this problem is too complex to find a solution for it in this Q&A. Could you contact tech support or use the "Send feedback" option in the DIS menu so we can investigate this in depth?
Stephen Goode [DevOps Advocate] commented 12th November 2024
thanks Davor, i've just checked and Visual Studio 2022 is at the latest version (17.11.5) and it seems to be using Visual Studio 2019 is no longer possible. will send feedback for investigation as you recommend
Hi Stephen,
Show 1 more comments
Pedro Debevere [SLC] [DevOps Enabler]2.89K Posted 12th November 2024 1 Comment
Hi Stephen,
As Davor pointed out, this can occur when the DIS extension is installed on a Visual Studio version that is outdated. Updating Visual Studio to the latest version (17.11.5) should resolve the issue. Note: Trying on VS2019 is not possible as recent versions of DIS are only supported on VS2022 and the templates functionality was not made available in DIS for VS2019.
hi Pedro,
my Visual Studio 2022 is already 17.11.5 and sadly i still see this error – i've tried uninstalling and reinstalling the DIS extension
