Issue with visio
Solved1.15K views1st April 2025Visio Visual Overview
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K 1st April 2025 0 Comments
Hello,
I noticed today that there is an issue with some Visios we have, I’ve identified the issue to be correlated to:
Cube/Client version: Not present in 10.5.2505.3334, issue present in 10.5.2509.2672
Visio is connected to a service and shape data “Element” is set to “[this service]” or “[this serviceid]”, however the actual placeholders seem to work when used in text.
I was able to recreate the issue using a very basic Visio that can be applied to any service.
Here is the result of opening the attached Visio in each version of Cube:
Would appreciate some ideas on this issue.
Thanks in advance.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 1st April 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 1st April 2025 2 Comments
Hi Arunkrishna,
This issue is present in the latest Cube version. We’re actively working on a fix and will provide an update here once it’s resolved.
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 1st April 2025
Hi Seba,
Thank you, do you have a release note or a task ID for reference ?
Toon Casteele [SLC] [DevOps Enabler] commented 1st April 2025
Hi Arunkrishna, I'll get it over to you through chat.
