Issue while exporting/importing elements from 9.6 to 10.3
Solved2.18K views19th July 20239.6 Import CSV
Carolina Costa [SLC] [DevOps Advocate]1.03K 27th June 2023 0 Comments
Hello DataMiner community,
We are planning to do a transfer of the Views and some elements from a system (using DataMiner version 9.6) to a new setup using 10.3.
Regarding the elements, we could already successfully transfer some of them, but we found a couple of issues that we would like your insights.
When importing the ExportData.csv file containing the elements to be created, besides changing the dataminer ID and removing the element IDs, we noticed that from 9.6 to 10.3, there are some differences in the header of the csv file. Namely, in the newer version there were added the following headers: ReplicationMaxBuffer,ReplicationMinBuffer,ProtocolType,CredentialGUID,TLS,AllowedIpAddresses,ConnectTimeoutTime.
Besides that, we couldn’t find any differences between the two headers (neither on naming nor on sorting).
After this brief overview, I am now finding and blocked with an issue:
  • When importing elements with more than one connection (2 SNMP and 1 SSH in this case), the first connection works just fine, but the other ones don’t get correctly filled (they are missing the IPs, ports,...). For this one, I suspect that there is a shift in the csv file that it is causing the loss of all the configuration for the other connections. I did a comparison from an export from 10.3 and the export from 9.6, but besides some custom properties and trend/alarm templates, I cannot find what is shifted.
Does anyone already did this and knows what it might be wrong and how can I fix it?
Koen Annys [SLC] [DevOps Advocate]144 Posted 27th June 2023 1 Comment
I believe the feature "export elements to .dmimport file" will be more beneficial to you. This method e.g. will allow you to extract trend and alarm data as well.
More info can be found here.
Carolina Costa [SLC] [DevOps Advocate] Posted new comment 27th June 2023
Carolina Costa [SLC] [DevOps Advocate] commented 27th June 2023
Hello Koen, thanks for your reply. In this case, I don’t think a dmimport will be the best option, as we don’t want to migrate the elements. We want new element IDs with the same configuration. Another issue with this approach is that the credentials will get lost, while we were using the credentials GUIDs in the csv (from the credentials library) to get the credentials.
