Is there a way to lock parameters from being changed by other uses?
Solved759 views29th August 2025Connector Write Paramter
Anna Carlsson [DevOps Member]444 19th February 2025 3 Comments
I have a connector that requires an update of a number of parameters before a request is sent to the device to configure the device.
For example: A use case is to configure a user on the device. In Dataminer Cube I need to set user name, password and a number of additional parameters. When the parameters are updated I click configure user and a request is sent to the device with the updated parameters.
But, there can be another operator that is configuring a user at the same time, i.e. the same connector parameters are used for that, which means that same parameters are configured by different operators.
Is there a way to temporary set these writable parameters to non-writable for other users?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th August 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 19th February 2025
Hi Anna,
Could you check if locking an element cover your use case?
https://docs.dataminer.services/user-guide/Basic_Functionality/Elements/Working_with_elements/Locking_and_unlocking_elements.html
Anna Carlsson [DevOps Member] commented 19th February 2025
Thank you for the tip. We will test and see if this works.
Marieke Goethals [SLC] [DevOps Catalyst] commented 29th August 2025
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 26th June 2025 0 Comments
Hi Anna,
I noticed that this question has been open for some time now. Could you confirm if the proposed solution indeed worked, so we can mark this question as solved?
