Is there a way to bulk provision devices other than IDP?
Solved1.83K views30th September 2024
Oscar Eves [DevOps Advocate]356 11th June 2024 2 Comments
We have a number of devices spread across numerous subnets which also contain other devices we do not want to provision, making IDP a not as suitable option here so was wondering if there were any alternative ways to bulk provision these devices
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 11th June 2024 0 Comments
Hi Oscar,
IDP can scan the configured subnets but that does not mean it automatically provisions all of the available network devices. You can configure only the relevant CI Types and provision these elements accordingly.
Kind Regards,
Jarno
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 11th June 2024 0 Comments
I would suggest to create one element for a specific protocol, do an export (right-click > Actions > Export) and export it as CSV. Then you can duplicate the row, but leave the DataMiner ID and Element ID empty for the new rows and change element row and the polling configuration. Then do an import of that file to create the elements (right-click the view > Actions > Import).
The end of this course also covers this:
Elements – DataMiner Dojo
Michiel Saelen [SLC] [DevOps Advocate] Answered question 11th June 2024
