Is .Net 3.5 Required to run “Clean XBAP Cache” for Cube Clients?
Solved1.75K views17th July 2023.net .net 3.5 cube xbap cache
Michael Wells [SLC] [DevOps Member]502 28th March 2022 0 Comments
Can someone confirm that .Net 3.5 is required to be installed on systems with Cube in order to use the Clean XBAP Cache utility that can be downloaded from http://[dataminerip]/tools ?
Bert Buysschaert [SLC] [DevOps Advocate]5.32K Posted 28th March 2022 0 Comments
Hi Michael,
Yes, this tool hasn’t been updated since 9.0 and is still compiled against the .NET 2.0 / 3.5 Framework. Installing the .NET 3.5 component in Windows is one option, but if it is just to run once, it might be easier to close all Internet Explorer windows and run the following command instead:
rundll32.exe dfshim.dll CleanOnlineAppCache
