Is it supported to perform a set on a direct view parameter from an Automation script?
Solved2.64K views10th June 2020Automation direct view table
7
Laurens Moutton [SLC] [DevOps Enabler]9.90K 10th June 2020 0 Comments
When there is a direct view table with a write parameter, then values can be set through the element card.
I’m trying to execute a set parameter from an Automation script, but I get “invalid data” when trying from C# code and also from a set parameter action. I have tried by specifying the PID of the real write parameter and with the PID of the duplicate parameter. I have tried by specifying the display key and also the primary key, but all combinations give the same invalid data error. Is it possible that sets on direct view tables are not supported from Automation scripts and I should implement a workaround in the driver or should something else be called in the Automation script SetParameter call?
Laurens Moutton [SLC] [DevOps Enabler] Selected answer as best 10th June 2020
Davy Degrande [SLC] [DevOps Advocate]1.81K Posted 10th June 2020 0 Comments
Currently there is no way to do this. There are tasks that have this planned in the future where the source ID will be filled in in the data so the set can be rerouted.
Marieke Goethals [SLC] [DevOps Catalyst] Edited answer 10th June 2020
