Is it possible to use Regexreplace with card-scope variables?
Solved2.56K views22nd July 2020Regexreplace
Gelber Mahecha [SLC] [DevOps Enabler]2.03K 21st July 2020 0 Comments
I want to use Regexreplace to extract element IDs from a session variable to link other shapes in the view. Although the concept works fine (I can control the element linked on each shape by changing that session variable), I need to have this working with a card session scope so I can open multiple cards with the same view and show different elements on each one.
Is there a way to make Regexreplace working on a scope different than the default?
Gelber Mahecha [SLC] [DevOps Enabler] Selected answer as best 22nd July 2020
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 22nd July 2020 0 Comments
The placeholder for card variables is different than the one for regular variables. So instead of using the [Var:MyVariable] placeholder you'll want to use the [CardVar:MyVariable] placeholder.
Do note that you also have the [PageVar:MyVariable] and [WorkspaceVar:MyVariable] to address page scoped and workspace scoped variables.
