Is it possible to Perform a Failover Switch via an Automation Script?
635 views4th September 2026Automation action Failover
Micah Brown [SLC] [DevOps Advocate]600 21st August 2026 1 Comment
Hello,
I was wondering if there is a current method for performing a failover switch via an automation script? This would be in the case where a failover switch is executed on the automation script to allow the newly offline agent to go through OS updates. Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 4th September 2026
Gelber Mahecha [SLC] [DevOps Enabler] commented 24th August 2026
Hi Micah,
Here is a link to a similar question from a few years ago. I guess the situation is the same today:
https://community.dataminer.services/question/perform-dma-failover-via-automation/?hilite=Failover+script
Marieke Goethals [SLC] [DevOps Catalyst]7.77K Posted 4th September 2026 0 Comments
I get the impression that this question has already been answered in the comments. If this is indeed the case, could you select this answer to indicate that the question can be closed and no further follow-up is needed?
