Is it possible to find the element using IP address with engine.FindElements()
Solved2.30K views11th July 2023ipaddress
Trong Huynh [DevOps Advocate]881 21st November 2022 0 Comments
I need to retrieve the element in my Automation Script. I have its IP address. There are a number of documented methods for finding elements using name, id, view etc, but is there a way to find the element using its IP address?
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 22nd November 2022 2 Comments
Hi Trong,
You can do this by using DMS_GET_ELEMENT_ID_FROM_IP (76).
Trong Huynh [DevOps Advocate] commented 28th November 2022
Thanks Jen. This works well.
However, for me it works inside a protocol QAction. When using it inside an Automation Script I get “namespace name ‘DMS’ could not be found” error in the Logs. Not sure why.
Jens Vandewalle [SLC] [DevOps Advocate] commented 29th November 2022
Hi Trong, have you tried by adding using Interop.SLDms;?
-2
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 21st November 2022 1 Comment
Hi Trong,
I believe there is not a specific method that you could use to get an element based on the IP address. However, you could proceed as follows:
// Get all the elements in the cluster (Root view = -1)
Element[] lElements = engine.FindElementsInView(-1);
// Get Element based on polling IP
Element myElement = lElements.Where(element => element.PollingIP == “10.11.12.13”).First();
if (myElement != null)
engine.GenerateInformation(“Element name=” + myElement.ElementName);
Trong Huynh [DevOps Advocate] Posted new comment 28th November 2022
Thanks Miguel. This solution works also.
