Is it possible to export trending to CSV via an automation script or another method ?
Solved715 views20th August 2025real time trending trending data
Alexandre Bonnet [DevOps Advocate]453 4th June 2025 0 Comments
Hello Dojo,
I was able to export trending data to csv via this method, but since we need to do this action for multiple trends on a daily basis.
https://docs.dataminer.services/user-guide/Basic_Functionality/Trending/Working_with_trend_graphs/Exporting_a_trend_graph.html?q=exporting%20a%20trend%20
Is there a way to automate those actions via a script ?
If so do we have acces to the same parameters listed in the link (Fixed interval , exclude gaps etc...)
Are there alternative methods to retrieve trending data ?
Thank you,
Best regards,
Alexandre
Alexandre Bonnet [DevOps Advocate] Selected answer as best 20th August 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 4th June 2025 0 Comments
Hi Alexandre,
A possible option is using the web API call GetTrendDataForParameter or GetTrendData CustomTimespanForParameter to retrieve this information.
Hope it helps.
