Is it possible to create dataminer users automatically?
Solved2.04K views21st December 2023System Administration
Bruno Sousa [DevOps Member]669 18th December 2023 0 Comments
Hello,
Is it possible to create Dataminer users in an automatic way? (API, for example..)
Thank you.
Best regards
Bruno Sousa
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st December 2023
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 19th December 2023 2 Comments
Hi Bruno,
DataMiner has option to add Domain users/groups. You can find more details for adding single user here and you can find more details for adding whole domain groups here.
Edit:
You could try using User-Defined APIs as well to add user, it would require more effort on your side but I'm pretty sure you could do it that way, don't quote me on that one though. 😀
Hopefully this helps,
Cheers
Edib Šupić [SLC] [DevOps Enabler] Posted new comment 20th December 2023
Bruno Sousa [DevOps Member] commented 19th December 2023
Can you please provide some documentation on Dataminer Framework ( C# functions, etc) that allows user and group configuration? (add, delete, edit, etc,)
Thank you.
BR
Bruno Sousa
Edib Šupić [SLC] [DevOps Enabler] commented 20th December 2023
Hi Bruno,
I’ve consulted with more senior colleague and since implementing this could pose a security risk, I will let someone with more experience provide you with an answer, to make sure there are no security risks.
