Is it possible to automatically group alarms based on element or alarm properties?
Solved3.10K views11th July 2023
Dennis Dreesen [SLC] [DevOps Advocate]642 25th March 2022 0 Comments
One of our users reached out because they would automatically like to group alarms together that are related to the same location (ie site). This site is mentioned as a property. Is it possible to do so? How can I do this? Does this functionality belong to the core DataMiner software?
Thanks in advance,
Dennis
Bruno Dias [SLC] [DevOps Member]2.39K Posted 25th March 2022 0 Comments
Other alternative is to use the Correlation rule engine, to define a rule that groups alarms based on property. The same is possible for Views, Services, Elements, parameter, table index, etc.
Further details are available in our documentation: Grouping alarms in Correlation rules | DataMiner Docs
Bruno Dias [SLC] [DevOps Member] Answered question 25th March 2022
You are viewing 1 out of 5 answers, click here to view all answers.
