Is dataminer able to support device using MQTT protocol?
Solved3.77K views20th March 2024
Tser Siong Toh [DevOps Advocate]231 18th March 2024 0 Comments
Dear Sir/ Mdm,
Please advise if dataminer is able to communicate with devices using MQTT protocol?
And what is the best approach to integrate with devices using MQTT protocol?
Look forward for your advice.
Thanks,
Best Regards,
Toh
Leander Druwel [SLC] [DevOps Member] Answered question 20th March 2024
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 18th March 2024 2 Comments
Hi Tser,
DataMiner already integrates with devices (IoT) using MQTT.
You can use readily available Nuget packages such as this (MQTTNet) to write a DataMiner connector (protocol, driver) to bring data from the broker or to act as client.
As far as best practices, you can rely on available documentation such as this (MQTT Essentials - All Core Concepts Explained (hivemq.com))
Thanks,
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 20th March 2024
Tser Siong Toh [DevOps Advocate] commented 19th March 2024
Just to confirm that can dataminer integrate with devices using MQTT?
Rene De Posada [SLC] [DevOps Advocate] commented 19th March 2024
Yes, it can. Thanks
