Is dataminer able to support device using MQTT protocol?
Solved3.87K views20th March 2024
Tser Siong Toh [DevOps Advocate]231 18th March 2024 0 Comments
Dear Sir/ Mdm,
Please advise if dataminer is able to communicate with devices using MQTT protocol?
And what is the best approach to integrate with devices using MQTT protocol?
Look forward for your advice.
Thanks,
Best Regards,
Toh
Leander Druwel [SLC] [DevOps Member] Answered question 20th March 2024
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 18th March 2024 2 Comments
Hi Tser,
DataMiner already integrates with devices (IoT) using MQTT.
You can use readily available Nuget packages such as this (MQTTNet) to write a DataMiner connector (protocol, driver) to bring data from the broker or to act as client.
As far as best practices, you can rely on available documentation such as this (MQTT Essentials – All Core Concepts Explained (hivemq.com))
Thanks,
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 20th March 2024
Tser Siong Toh [DevOps Advocate] commented 19th March 2024
Just to confirm that can dataminer integrate with devices using MQTT?
Rene De Posada [SLC] [DevOps Advocate] commented 19th March 2024
Yes, it can. Thanks
Leander Druwel [SLC] [DevOps Member]2.11K Posted 20th March 2024 1 Comment
Hi Tser,
I want to add that we are currently developing an MQTT Client connector, which would be capable of receiving and sending information via MQTT. The connector is expected to be released within the next month to come.
Summary of first functionalities:
  • Connection to an MQTT broker, with support on authentication and TLS.
  • Statistics on message retrieved from the MQTT broker
  • Ability to define on which topics the element should subscribe, including possibility of using industry standard filters
  • Received message visualization and the ability to map topics, or subcategories to DataMiner Virtual Elements (DVEs), in order to show related received KPIs grouped per element.
  • Ability to publish information onto an MQTT broker.
More news to come 🙂
So comments above are correct, DataMiner can integrate with devices using MQTT.
MAXIMILIANO FILHO [DevOps Enabler] Posted new comment 6th March 2025
MAXIMILIANO FILHO [DevOps Enabler] commented 6th March 2025
Hi Leander,
Is this protocol already finalized? I need to create an element that functions as an MQTT client, subscribing to topics to receive messages. The problem is that the execution of the process must be uninterrupted. Thanks in advance
