IP setting – sequence of NIC changed
Solved1.94K views22nd September 2023
Syed Taj uddin [DevOps Member]403 28th August 2023 0 Comments
Hi
Our DMA (1+1) showing this notice, but we did not change the NIC address or cables. Can someone let me know what could be the cause of this error. I am getting these alarms after we upgarde from 10.2.0.0 to 10.3.0.0 13184 dataminer version.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd September 2023
Syed Taj uddin [DevOps Member]403 Posted 19th September 2023 1 Comment
Even after locking the specific NIC for each network, its giving the below notice.
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd September 2023
This looks like an issue that will require a deeper investigation than is possible here. Could you contact techsupport@skyline.be for assistance?
Simon Raine [SLC] [DevOps Member]2.08K Posted 28th August 2023 1 Comment
Hi Syed,
This could change for a number of reasons, but without configuration, DataMiner will take the first one in the priority as defined by windows. To lock to specific NIC for each network you can configure this in the DataMiner.xml. see- DataMiner.xml | DataMiner Docs
I hope this solves the problem.
Syed Taj uddin [DevOps Member] Edited comment 19th September 2023
Syed Taj uddin [DevOps Member] commented 4th September 2023
@simon
I did these changes already but still the same issue.
