Information events generated while using smart baseline
Solved2.34K views24th May 2023smart baseline
8
Jarno Lernou [SLC] [DevOps Enabler]6.08K 23rd March 2023 2 Comments
I'm using the following type attribute | DataMiner Docs to enable the smart baseline functionality for a given parameter.
<Alarm type="relative:NOMINAL_VALUE_PID,FACTOR_PID">
Now when checking the information events, I see quite some being generated for the parameter used as the 'nominal value'. Is there any possibility to get this disabled?
Thank you!
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 24th May 2023
Joey Vanhalst [SLC] [DevOps Advocate] commented 23rd March 2023
Hi Jarno, is there any specific use case why you need to define the alarming type in the connector instead of the alarm template only?
Jarno Lernou [SLC] [DevOps Enabler] commented 23rd March 2023
When using a parameter for filling in the ‘nominal value’ for the baseline, then we can look to the trend of this parameter. This way we can analyze the calculated baseline and verify the alarms being generated.
Laurens Moutton [SLC] [DevOps Enabler]9.91K Posted 23rd March 2023 0 Comments
Hi Jarno,
I'm afraid that is not possible (yet). The problem is that the new baseline value enters through a set on a write parameter, just like any other normal set from a user would enter. As that write parameter has RTDisplay true, it will generate an information event.
The solution to avoid the information event would be to set RTDisplay false, but then the smart baseline will not know the id of the parameter anymore to perform the set on as non displayed parameters are not known, so that's also not a valid solution :/ .
Regards,
Pieter Van Compernolle [SLC] [DevOps Enabler] Unselected an answer 24th May 2023
