Incorrect PortSetting after element creation
Solved2.30K views28th October 2020
6
Wannes Wittevrongel [SLC] [DevOps Member]169 27th October 2020 0 Comments
After element creation we noticed that the newly created element was not polling. After some investigation the element settings seem to be incorrect. When retrieved with the client test tool we can see that the port type is set to SNMPV2 instead of HTTP.
element settings:
We are currently using DataMiner (9.6.13.0-8820-CU1). Is this a know issue or do you know anything that can explains this behavior?
Wannes Wittevrongel [SLC] [DevOps Member] Selected answer as best 28th October 2020
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 28th October 2020 0 Comments
This is a known issue in DataMiner 9.6.13.
It has been resolved in DataMiner 10.0 and later.
