In LCA when column is customized the hyperlink functionality doestn’t work
Solved1.54K views29th August 2025LCA
Apurva Tandon [DevOps Member]1.73K 21st February 2025 2 Comments
I ahve a page like this so on right side I have column customized (URL) which has edit delete and hyperlink on the URL which should open the URL, but edit and delete seems to work but not the hyperlink on hover it shows <u>{URL}</u>
Please see the setting I did:
Dont know whats missing aor what is wrong
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th August 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 29th August 2025
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 21st February 2025 3 Comments
The content of the text in the template editor is in html. You currently have an underlined piece of text which happens to contain a URL. To turn it into an actual hyperlink you need to use the html anchor tag:
<a href=”{URL}”><u>{URL}</u></a>
Wout Mahieu [SLC] [DevOps Catalyst] commented 21st February 2025
Alternatively, actions can also be used. The 'navigate to URL' action should fit your needs.
Apurva Tandon [DevOps Member] commented 21st February 2025
How toa achieve navigate to URL thing?
I can see if remove that edit and delete icon and just say hyperlink for URL it works and it opens on new tab, but not with edit and add when customized
Also, with what Toon suggested it tries to open on the same tab that url
To open the URL in a new tab, you should add a target: <a href="{URL}" target="_blank">{URL}</a>
Wout Mahieu [SLC] [DevOps Catalyst]12.45K Posted 21st February 2025 0 Comments
Next to the answer of Toon, there is a way to achieve this using actions:
  1. Add a shape on top of the text shape in the template. Configure the color to be transparent.
    1. This is an extra step because actions cannot currently be added to text shapes
  2. Add an ‘Navigate to URL‘ action to the newly added shape. As a URL you can configure the column value using interpolation {URL}.
When this shape is now clicked, the action will execute and navigate to the URL that is specified in the column.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 21st February 2025
