In Alarm Console, how do we filter out blank cells?
Solved3.90K views10th September 2021Alarm Console alarm filters
Steve Purcell [SLC] [DevOps Advocate]2.65K 9th September 2021 0 Comments
We want to be able to use the Alarm Console filter (services:) to only show alerts where the services field is populated.  We have tried different entries (services:!””, services:*), however, the alarms with the Services column blanks continue to appear.  Is there a way to set the Alarm Console filter to filter out blanks?
bruno santos [SLC] [DevOps Advocate] Answered question 10th September 2021
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 9th September 2021 1 Comment
Hi Steve,
While this doesn’t answer the question of how to filter out empty cells, you should be able to filter out alarms that impact a service by using:
“Service impact”:>0
Steve Purcell [SLC] [DevOps Advocate] Posted new comment 9th September 2021
Steve Purcell [SLC] [DevOps Advocate] commented 9th September 2021
Thank you Ive, this worked great at the quick filter level.
bruno santos [SLC] [DevOps Advocate]1.30K Posted 10th September 2021 0 Comments
It seems you can’t do it on the quick search bar, but creating a new tab with a custom filter allows you to use regex. see the screenshot below to filter out empty services or any other field
bruno santos [SLC] [DevOps Advocate] Edited answer 10th September 2021
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 9th September 2021 1 Comment
Hi Steve,
not an answer to your question, but maybe a solution for your goal: there is a property called Service Impact, which gives you the nbr of services impacted.  Could you not filter on that one?
Ben Vandenberghe [SLC] [DevOps Advocate] Posted new comment 9th September 2021
Ben Vandenberghe [SLC] [DevOps Advocate] commented 9th September 2021
You can definitely use that to create a tab page with only alarms that are service impacting (by filtering on Service Impact > 0). But not sure if this can be done with the quick filter at the bottom though, and whether you need to be able to do that via the quick filter.
