How to switch between tabs from a same visio using a button?
Solved766 views1st June 2026
Sergio Souza [DevOps Member]58 29th May 2026 0 Comments
I have 6 tabs in 1 visio file and I'd like to create in first tab a view with some buttons to change between tabs.
Anyone can sugest a good way to implement this idea?
Thanks in advance.
Sérgio Romero
Sergio Souza [DevOps Member] Selected answer as best 1st June 2026
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 30th May 2026 0 Comments
Hi Sergio,
I believe you are looking for the shape data NavigatePage, more info can be found here:
Creating a button to navigate to a page of the current Visio drawing | DataMiner Docs
This docs page also refers to the example on our Ziine demo platform. If you connect to ziine.dataminer.services, you will find a view 'Visual Overview Design Examples'. The Visio of this view contains a lot of examples and the Visio file can also be downloaded.
This is a screenshot of the example of this feature in that Visio file:
Bert
