How to retrieve View of existing element
Solved2.12K views27th October 2021Automation script element view
Stijn Declerck [SLC] [DevOps Advocate]834 27th October 2021 0 Comments
Hi all,
In an automation script I would like to create an element in the same view as an existing element. I’m able to retrieve the required element and to create the new one, but I’m struggling to assign the correct view to that element. Does anyone know how to do this?
Thanks,
Stijn
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 27th October 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 27th October 2021 1 Comment
Hi Stijn,
The following code can help you to retrieve the view of an element:
// Create a IDms object to go through the elements in the cluster
IDms dms = engine.GetDms();
// Retrieve the elements in the cluster
ICollection<IDmsElement> dmsElements = dms.GetElements();
foreach (IDmsElement dmsElement in dmsElements)
engine.GenerateInformation(“[INFO]|Run|dmsElement.Name=” + dmsElement.Name);
engine.GenerateInformation(“[INFO]|Run|dmsElement.Id=” + dmsElement.Id);
engine.GenerateInformation(“[INFO]|Run|dmsElement.Host=” + dmsElement.Host.Id);
// Get the views for an element
ISet<IDmsView> dmsViews = dmsElement.Views;
foreach (IDmsView dmsView in dmsViews)
engine.GenerateInformation(“[INFO]|Run|dmsView.Name=” + dmsView.Name);
}// End foreach
}// End foreach
And to create an element in a specific view, you need to create your ElementConfiguration object as follows:
elementConfiguration = new ElementConfiguration(dms, “My Element”, dms.GetProtocol(“My Protocol”, “Production”));
elementConfiguration.Views.Add(dms.GetView(“My View”));
Jens Vandewalle [SLC] [DevOps Advocate] Edited comment 28th October 2021
Jens Vandewalle [SLC] [DevOps Advocate] commented 28th October 2021
Note that in case you know the existing element, you wan work with dms.GetElement([elementName]) or dms.GetElement([dmaId],[elementId])
