How to retrieve SNMP traps from a Cisco Nexus switch in DataMiner?
Solved1.98K views13th August 2020Cisco Nexus SNMP traps
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 12th August 2020 0 Comments
The DataMiner Cisco Nexus driver has a "trap receiver" data page. What do I need to configure on a Cisco Nexus to send SNMP traps to DataMiner?
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 13th August 2020
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 12th August 2020 0 Comments
Hi Thomas,
A detailed description on how to configure your Cisco NX-OS system to forward traps can be found here.
e.g.
Use the following command in global configuration mode to configure a host receiver for SNMPv2 traps:
snmp-server host 192.0.2.1 traps version 2c public
Where 192.0.2.1 should be the IP of the DataMiner server hosting your Nexus element.
