How to mask and/or clear alarm using automation script?
Solved165.64K views19th July 2023Automation script clear mask
Mateusz Kalisiak10 30th March 2021 0 Comments
Hello,
I need to automatically clear (and in some cases mask) particular alarm after an action is taken using tool created as automation script (i.e. Hyperlink). For alarm masking I know that there is WebService method MaskAlarm, but can’t find anything with regards to alarm clearing. Is it even possible to clear/mask alarm using any Engine methods?
Regards,
Mateusz
Jarno Lernou [SLC] [DevOps Enabler]5.70K Posted 31st March 2021 0 Comments
Hi Mateusz, I would recommend you to check the DataMiner Automation course, available for free on Dojo. In this course, there are two videos that might be relevant to your question.
In the video ‘Executing scripts from Correlation‘, you will learn how to automatically trigger an Automation script on certain events by making use of correlation. In this video, parameter sets are used (backupElementStream.SetParameter(203, idx, (int)VlcInstanceState.Paused)) and element alarm masking (backupElementStream.Mask(“Main Stream is running.”)) as well.
In the video ‘Executing scripts from the Alarm Console‘, you will learn how to trigger an Automation script by using the context menu on an Alarm in the Alarm Console.
I hope this helps you further.
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 11th April 2021 0 Comments
Hi Mateusz,
As far as I know there is no Engine method that is able to mask a specific alarm. As Jarno indicated, you could mask an element (that will also mask the alarm).
However, there is a SLNet call that you could use to mask an alarm. Please find below an example (tested using DMA version 10.1.3.0):
using System;
using Skyline.DataMiner.Net;
using Skyline.DataMiner.Net.DataMinerObjectReferences;
using Skyline.DataMiner.Net.Masking;
public class Script
// From Hyperlink
ScriptParam spDmaId = engine.GetScriptParam(“DMAID”);
ScriptParam spAlarmId = engine.GetScriptParam(“ALARMID”);
ScriptParam spRootKey = engine.GetScriptParam(“ROOTKEY”);
// Convert to integer
int iDmaId = Convert.ToInt32(spDmaId.Value);
int iAlarmId = Convert.ToInt32(spAlarmId.Value);
int iRootKey = Convert.ToInt32(spRootKey.Value);
// Define a RefTreeHelper object
DMAObjectRefTreeHelper dMAObjectRefTreeHelper = new DMAObjectRefTreeHelper();
// Setup the RefTreeHelper object
dMAObjectRefTreeHelper.SetupHelper(engine.SendSLNetSingleResponseMessage);
dMAObjectRefTreeHelper.ChangeMaskInfo(
new DMAObjectRefTree(new Skyline.DataMiner.Net.Messages.SLDataGateway.AlarmID(iDmaId, iAlarmId, iRootKey)),
//new MaskInfo(MaskType.UntilTimeElapsedOrUnmask, 60 /*Number of seconds*/, “Reason for masking”),
//new MaskInfo(MaskType.UntilClearanceOrUnmask,”Reason for masking”),
new MaskInfo(false), // Unmask the alarm
new CPECrawlerConfiguration()
Disclaimer:
Note that this is an internal call and we do not recommend using this, as it is not officially supported and we cannot guarantee that it will still work in the future. As a rule, you should avoid using SLNet calls, as these are subject to change without notice. We recommend to instead always use the correct UI or automation options provided in DataMiner Automation or through our web API.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 11th April 2021
