How to Mask Alarms in Advance for Scheduled Maintenance?
Solved2.34K views21st February 2025Alarm Console alarm masking alarmings Masking
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.87K 13th February 2025 0 Comments
I have a question from a user: Can we mask a row or multiple rows of a table in advance to prevent an alarm from being generated?
For example, in the image below, the user wants to perform testing or maintenance on the highlighted interface, which would normally trigger alarms. Before the alarm is generated, can the user mask that interface in advance so that no alarm is triggered or appeared in active alarm when testing or maintenance begins?
Is there any other way to suppress alarm generation for that interface beforehand, aside from the masking method?
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 21st February 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 13th February 2025 3 Comments
Hi Jeeva,
Adding an extra option to the previous answer (and as a last resort), you could potentially mask a row. This option is not available by default (it will need to be implemented in an automation script). Below a small demo:
Code snippet:
using Skyline.DataMiner.Net;
using Skyline.DataMiner.Net.DataMinerObjectReferences;
using Skyline.DataMiner.Net.Enums;
/// <summary>
/// Represents a DataMiner Automation script.
/// </summary>
public class Script
/// <summary>
/// The script entry point.
/// </summary>
/// <param name="engine">Link with SLAutomation process.</param>
Element element = engine.FindElement("TEST_ELEMENT");
int elementId = element.ElementId;
int dmaId = element.DmaId;
int tablePid = 1; /*Se the table PID*/
string tableIndex = "tableIndex"; /*Set the index of the row*/
string reasonMasking = "Test"; /*Reason for making */
MaskRow(engine, dmaId, elementId, tablePid, tableIndex, reasonMasking);
public static void MaskRow(IEngine engine, int dmaId, int elementId, int tablePid, string tableIndex, string reasonMasking)
DMAObjectRefTreeHelper helper = new DMAObjectRefTreeHelper();
helper.SetupHelper(engine.SendSLNetSingleResponseMessage);
// Define the row to be masked
RowID rowId = new RowID(dmaId, elementId, tablePid, 0, tableIndex);
helper.ChangeMaskInfo(
new Skyline.DataMiner.Net.DMAObjectRefTree(rowId),
new Skyline.DataMiner.Net.Masking.MaskInfo()
DoMask = true,
MaskType = MaskType.UntilUnmask,
Reason = reasonMasking,
new CPECrawlerConfiguration());
Hope it helps.
"Note that this is an internal call and we do not recommend using this, as it is not officially supported and we cannot guarantee that it will still work in the future. As a rule, you should avoid using SLNet calls, as these are subject to change without notice. We recommend to instead always use the correct UI or automation options provided in DataMiner Automation or through our web API."
Alberto De Luca [DevOps Enabler] commented 13th February 2025
That's interesting – thanks for sharing, Miguel.
In this bespoke approach, are you removing the row or just masking an existing alarm?
Miguel Obregon [SLC] [DevOps Catalyst] commented 13th February 2025
Hi Alberto,
In the demo, I showcase the 'mask row' feature. By default, if a row is removed and then recreated with the same index, any alarm associated with that row will lose its masking state. In de the animation, you will notice that when the row (with the same index) is re-created, the masked state for the alarm persists.
Miguel Obregon [SLC] [DevOps Catalyst] commented 14th February 2025
Snipped added as reference.
