How to mask alarms from a single interface?
Solved2.29K views11th July 2023
Jorge Sienra [SLC] [DevOps Member]375 10th January 2022 0 Comments
The idea is to be able to quickly mask and unmask alarms coming from one or more interfaces in a device, without having to mask the entire device.
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 11th January 2022 0 Comments
Hi Jorge,
In the alarmconsole you can right click on an alarm and pick the option "Mask alarm...". Here you can choose to mask only the selected alarm(s).
You can also add the action column "Masking" in your alarmconsole. If you hover the alarm an icon will become visible in that column and when clicking it you can mask the alarm.
Do note that in both cases a popup will be shown to ask what exactly you want to mask.
Michaël Pincket [SLC] [DevOps Advocate] Answered question 11th January 2022
