How to import Element Connections ?
Solved1.91K views11th July 2023
Bernard Pichot [SLC] [DevOps Advocate]1.43K 26th October 2020 0 Comments
In the Element Connections app it's possible to export the connections to a CSV file.
Is it possible to import the connections also from a file ?
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 29th October 2020 0 Comments
Valid request Bernard, but this is not possible.  The export file is mainly to read the configuration in a CSV.  It holds no identifiers, but has the resolved element name and parameters.
