How to immediately activate smart baseline alarming
Solved2.52K views18th July 2023alarm smart baseline
Laurens Moutton [SLC] [DevOps Enabler]9.61K 15th April 2021 0 Comments
Hi, for existing elements I want to switch from fixed alarming to smart baselines. Trending has already been activated, so this information is already present.
When I activate the alarm template it doesn't seem to do much. I consulted the help page and found that smart baselines are calculated at midnight. This means that I'll probably need to wait till midnight before this is calculated and don't have alarm monitoring for the rest of the day.
Is there a way to force the initial calculation? Trending is available so it should be possible to calculate a baseline.
Alberto De Luca [DevOps Enabler]5.36K Posted 15th April 2021 0 Comments
I seem to have an option to use the current value as baseline (right click to display): I haven't used this very much so far, but perhaps you can see if by skipping the last 24h you can achieve the desired result?
