How to get alarm’s Severity and Root Time as entry parameter for an automation script?
Solved2.85K views19th July 2023Automation script getalarmproperty getscriptparam
Mateusz Kalisiak10 8th March 2021 0 Comments
I'm implementing custom tool to create ticket for selected alarm. Tool is impelemented as automation script. I'd like to get Severity and RootTime as script parameters, but not able to do that. I'm able to fetch  Tool should fetch as much data as possible from alarm itself. I'm able to fetch attributes like alarmId and rootId using the following functions - engine.GetScriptParam("rootId").Value; engine.GetScriptParam("alarmId").Value). Also, I'm able to get custom alarm properties with GetAlarmProperty. Is there a way to get in a similar way Severity and RootTime?
The following - engine.GetScriptParam("Severity").Value - does not work.
Stacey Van Colen [SLC] [DevOps Member]2.75K Posted 8th March 2021 0 Comments
Hi Mateusz,
To get the RootID and Severity, you can use the following code. You only need to supply the GetAlarmDetailsMessage with the DataMinerID and AlarmID.
GetAlarmDetailsMessage message = new GetAlarmDetailsMessage(iDmaID, iAlarmID);
DMSMessage[] responseMessage = Engine.SLNet.SendMessage(message);
if (responseMessage.Length > 0)
AlarmEventMessage alarmEvent = (AlarmEventMessage)responseMessage[0];
int RootAlarmID = alarmEvent.RootAlarmID;
string severity = alarmEvent.Severity;
Stacey Van Colen [SLC] [DevOps Member] Answered question 8th March 2021
