How to enable TLS over smart serial connections
Solved905 views30th June 2023
Gelber Mahecha [SLC] [DevOps Enabler]1.97K 23rd June 2023 0 Comments
We integrate with a third-party application using a smart serial connection. Over that connection, DataMiner receives a REST call with a JSON document we capture and parse.
The customer wants to enable TLS to enforce security, but I wonder what is required to process that secured invocation from our side. As an alternative, I'm thinking of transferring that part of the integration to an UserDefinable API, but I wonder about the implications of such a change.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th June 2023
Miguel Obregon [SLC] [DevOps Catalyst]22.15K Posted 23rd June 2023 1 Comment
Hi Gelber,
You can find this information in DataMiner docs: Enabling TLS encryption for serial communication
Hope it helps.
Gelber Mahecha [SLC] [DevOps Enabler] commented 23rd June 2023
Thanks Miguel. I believe this is exactly what we need.
