How to display raw XML string in LCA component
Solved2.64K views15th April 2024grid component item template LCA string formatting
Jonas Kockx [SLC] [DevOps Member]287 15th April 2024 0 Comments
Hi
I noticed when trying to display a XML string in a grid component in LCA, that it is not displayed as the raw string.
E.g.:
New2604776177644032024/04/18 15:30:002024/04/18 16:00:002024/04/18 19:00:004a27bd2c-c010-409f-940b-3f512465c65d3 JPEG 2Kj2k150-PPNFL Atlanta Falcons vs. New Orleans SaintsSkyline Communications12906721280485150.5281MercedesBenzStadiumATLNFLMCRNY2024/04/13 05:10:12
Instead of:
<NMSHost><CircuitSetup><MessageType>New</MessageType><CircuitID>2604776</CircuitID><SharedID>17764403</SharedID><tLead>2024/04/18 15:30:00</tLead><tStart>2024/04/18 16:00:00</tStart><tEnd>2024/04/18 19:00:00</tEnd><ServiceType>4a27bd2c-c010-409f-940b-3f512465c65d</ServiceType><ServiceDescription>3 JPEG 2K</ServiceDescription><ServiceID>j2k150-PP</ServiceID><JobName>NFL Atlanta Falcons vs. New Orleans Saints</JobName><Client>Skyline Communications</Client><SequenceNumber>1290672</SequenceNumber><WorkOrder>1280485</WorkOrder><Capacity>150.528</Capacity><ProtectionID>1</ProtectionID><Source>MercedesBenzStadiumATL</Source><Path><Node>dtm11:1_LA-688-2</Node><Node>dtm2:8_LANim9</Node><Node>dtm6:1_TOR-688-1</Node><Node>dtm1:4_NYNim11</Node></Path><Destination>NFLMCRNY</Destination><TimeStamp>2024/04/15 08:23:42</TimeStamp></CircuitSetup></NMSHost>
How can I display the raw string in my grid component? (my string is a field of a DOM instance)
Jonas Kockx [SLC] [DevOps Member] Answered question 15th April 2024
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 15th April 2024 2 Comments
Hi Jonas,
Can you try replacing ‘<‘ with “&lt;”, ‘>’ with “&gt;” and ‘&’ with “&amp;”? You may also want to wrap entire string in <pre> tag to maintain the formatting.
Let me know if this helps,
Cheers
Edib Šupić [SLC] [DevOps Enabler] Edited comment 15th April 2024
Jonas Kockx [SLC] [DevOps Member] commented 15th April 2024
Encoding my string by replacing the helped. I’ve created a custom GQI operator which encodes that column for me. Thanks! (the tag didn’t seem to do the job at first sight)
Edib Šupić [SLC] [DevOps Enabler] commented 15th April 2024
I’m happy to hear that. Did you encode < and > in the <pre> tag? If you did, can you try without encoding them just for the tag, in this case we want <pre> to be interpreted as an HTML tag.
Jonas Kockx [SLC] [DevOps Member]287 Posted 15th April 2024 0 Comments
Based on the answers above I used this custom GQI operator to encode the column in my table (or a duplicated column). It uses HtmlEncode from System.Web
Note: make sure to set the following in your script XML:
<Param type=”preCompile”>true</Param>
<Param type=”libraryName”>HTMLEncode</Param>
GQI operator
using Skyline.DataMiner.Analytics.GenericInterface;
using System.Web;
[GQIMetaData(Name = “HTML Encode”)]
public class HTMLEncodeOperator : IGQIRowOperator, IGQIInputArguments
private GQIColumnDropdownArgument _htmlColumnArg = new GQIColumnDropdownArgument(“Column”) { IsRequired = true, Types = new GQIColumnType[] { GQIColumnType.String } };
private GQIColumn _htmlColumn;
public GQIArgument[] GetInputArguments()
return new GQIArgument[] { _htmlColumnArg };
public OnArgumentsProcessedOutputArgs OnArgumentsProcessed(OnArgumentsProcessedInputArgs args)
_htmlColumn = args.GetArgumentValue(_htmlColumnArg);
return new OnArgumentsProcessedOutputArgs();
public void HandleRow(GQIEditableRow row)
string html;
if (!row.TryGetValue(_htmlColumn, out html))
return;
var encoded = HttpUtility.HtmlEncode(html);
row.SetValue(_htmlColumn, encoded, encoded);
Seppe Dejonckheere [SLC] [DevOps Enabler]3.04K Posted 15th April 2024 1 Comment
Hi Jonas,
The grid component allows some html tags for markup purposes. It seems to me like the xml tags are being interpreted as html tags here, so they don’t show up as raw text (and they probably don’t show up in the DOM either, since those aren’t valid html tags).
In order to show the raw xml string, you probably will have to html encode the string.
Jonas Kockx [SLC] [DevOps Member] Posted new comment 15th April 2024
That was exactly the problem. I wrote a custom operator encoding my column by replacing some characters in my string as suggested in another answer. Thanks!
