How to display changes to DOM instances in low code apps?
Solved1.88K views3rd November 2022DOM GQI history low code apps
Miguel Barquet [SLC] [DevOps Advocate]2.00K 2nd November 2022 0 Comments
For some use cases, we need to create low-code apps that display history tracking of the values of DOM instances. A good example is a Ticketing application where users may want to know about previous changes to a given ticket and who made those changes.
Looking at the documentation, it is clear DOM keeps track of the changes DOM history | DataMiner Docs
This can be observed using the ClientTestTool.
I would like to know I can query this data available in Elastic and display it using Low-code Apps.
Looking at the GQI, I can't find a way to retrieve historic records.
Thanks in advance for your responses.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 3rd November 2022
Martijn Vanallemeersch [SLC] [DevOps Member]953 Posted 3rd November 2022 0 Comments
Hi Miguel, the audit trailing is indeed already saved in Elastic, currently it is only possible that you receive this information via automation. The goal is to imbed that in the forms component in apps similar to jobs (on the mid-term roadmap)
