how to create Arista 7060 and Cisco Nexus 93180 Dashboard
Solved2.97K views31st October 2023#cisco #arista #nexus #dashboard
Motoki Orikasa [DevOps Member]86 25th October 2023 0 Comments
Hi All,
We would like to create a Dashboard for Arista7060 and Nexus93180 in our Lab for InterBEE2023 in Japan.
We would like to show linkup/down, PTP trending and etc.
Please advise.
Cheers,
Motoki
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st October 2023
Motoki Orikasa [DevOps Member]86 Posted 28th October 2023 3 Comments
Hi Ive,
This is my current Dashboard Status.
Motoki
Motoki Orikasa [DevOps Member] Posted new comment 31st October 2023
Ive Herreman [SLC] [DevOps Enabler] commented 30th October 2023
Hi Motoki,
Can you verify if the detailed interface table shows any data in the element (in cube)?
If you see the data there, can you double-check if the element runs the selected protocol version (3.0.4.12)?
Motoki Orikasa [DevOps Member] commented 31st October 2023
Hi Ive,
The element seems to be working as version 3.0.4.12, but the “Detailed Interface” on the Cube does not show any data.
Hi Ive again,
additional info, FYI,
It worked on Arista 7060.
