how to create Arista 7060 and Cisco Nexus 93180 Dashboard
Solved2.83K views31st October 2023#cisco #arista #nexus #dashboard
Motoki Orikasa [DevOps Member]86 25th October 2023 0 Comments
Hi All,
We would like to create a Dashboard for Arista7060 and Nexus93180 in our Lab for InterBEE2023 in Japan.
We would like to show linkup/down, PTP trending and etc.
Please advise.
Cheers,
Motoki
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st October 2023
Motoki Orikasa [DevOps Member]86 Posted 27th October 2023 3 Comments
Hi Jeeva,
I have dragged and dropped Cisco93180YC into the Visual Overview component and went to the SettingsPage but could not find it.
How can I make it link to Visio?
Motoki
Motoki Orikasa [DevOps Member] Posted new comment 28th October 2023
Ive Herreman [SLC] [DevOps Enabler] commented 27th October 2023
Hi Motoki,
When you use a visual overview component in the dashboard app, you will see the visual overview that is assigned to your element. This is the exact same UI you get on the visual tab of your element in dataminer cube.
This means that if you wish to see the visual here, you’ll need to assign it to your element in cube first.
Alternatively, you could create your own dashboard using the individual dashboard components. I’ll post a sample gif in a dedicated answer.
Next to my comments above, if you have the Visio and would still like to incorporate it, this is possible. However, it seems that you might not have activated the visio yet. To do this, you can go to the protocol & templates app, select your protocol in the first column and right-click your visio (likely it will be named custom), and choose set as active Visio file.
Motoki Orikasa [DevOps Member] commented 28th October 2023
all good!
I will try that !
