how to create Arista 7060 and Cisco Nexus 93180 Dashboard
Solved3.03K views31st October 2023#cisco #arista #nexus #dashboard
Motoki Orikasa [DevOps Member]86 25th October 2023 0 Comments
Hi All,
We would like to create a Dashboard for Arista7060 and Nexus93180 in our Lab for InterBEE2023 in Japan.
We would like to show linkup/down, PTP trending and etc.
Please advise.
Cheers,
Motoki
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st October 2023
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.87K Posted 25th October 2023 3 Comments
Hi Motoki,
There are actually many examples and use cases you can explore to get an idea.
You can find them in the DataMiner Dojo use cases or on the Ziine platform.
Here are some interesting use cases I found in the Dojo Use Cases that could be related to your requirements:
Cisco – Tech Partner Integrations
Switch configuration with DataMiner Low-Code Apps
Arista – Tech Partner Integrations
You can also get a lot of ideas on the Ziine platform, where you can perform hands-on testing on the Dashboard and Apps. If you don't have access to Ziine, you can refer to this link.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 25th October 2023
Additionally, there is also an introduction course on how you can create a dashboard: https://community.dataminer.services/courses/dashboard/
Motoki Orikasa [DevOps Member] commented 27th October 2023
Hi All,
Thanks for sharing some info.
I just deployed the visio of Cisco Nexus now.
How can I import in the dashboard?
Jeeva Suria Rajah [SLC] [DevOps Enabler] commented 27th October 2023
Hi Motoki-san,
You can use the Visual Overview component in the Dashboard to display the Cisco Nexus Visio. Please find more information at this link:
https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Visualizations/Available_visualizations/Other/Visual_Overview_component.html?q=visiodashboard
You can also watch this video to get more idea:
https://community.dataminer.services/courses/dashboard/lessons/visualizations/topic/other/
