How to cope with smaller values when using relative monitoring?
Solved2.85K views2nd July 2021alarm monitoring alarm templates smart baseline
Michiel Saelen [SLC] [DevOps Advocate]6.55K 2nd July 2021 0 Comments
When using relative monitoring with the daily pattern we see when the value gets to lower values we get a lot of alarms (see the first screenshot). This is typical that during nighttime fewer devices are active (people are sleeping) and the number of devices during the night can vary much more than over the day. Next to this 90% of 10 (avg number of devices over x days during that 15min) is 9 devices, while the 90% of 200 devices are 180 devices, this means that during the night we can actually have less deviation that can occur on the number of devices compared to overday.
What is the best way to configure relative monitoring and avoid the alarms during nighttime, but still see anomalies like shown in the second screenshot?
Michiel Saelen [SLC] [DevOps Advocate] Selected answer as best 2nd July 2021
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 2nd July 2021 3 Comments
Hi Michiel. Can’t you work with two alarm templates that you activate via scheduler? Then you could create an alarm template for during the night, and another template for during the day, that can have different thresholds.
Laurens Moutton [SLC] [DevOps Enabler] Posted new comment 5th July 2021
Michiel Saelen [SLC] [DevOps Advocate] commented 2nd July 2021
Hi Tom,
Indeed using an automation script through the scheduler to assign different templates during day and night time is one of the options.
There is also the option to use alarm template groups that have a different schedule, but not a 100% sure (yet) if this would work as expected.
After some testing, working with an alarm template group containing both templates (for day and night) with a schedule seem the way forward.
Laurens Moutton [SLC] [DevOps Enabler] commented 5th July 2021
If this is a setup with a lot of devices, like an EPM setup, then you might want to verify the SLElement load at the time of switching the alarms if that isn’t taking up a lot of resources for a few minutes as that could have a negative impact on the other users of the system at that time when they try to access the data.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 2nd July 2021 1 Comment
Hi Michiel,
Have you looked into the option of alarm templates with dynamic thresholds?
There is an option to detect a deviation in the expected daily pattern.
e.g.
Michiel Saelen [SLC] [DevOps Advocate] Posted new comment 2nd July 2021
Hi Ive,
Indeed this is what we are using, during the daytime this is giving the wanted behavior, but not during the nighttime. During the nighttime, the number of devices is close to zero and can have a large deviation from day to day (e.g. ranging from 10 to 0 devices).
