How set a ethernet interface as default adapter to sync between DMAs in a DMS
Solved2.26K views17th July 2023Agent Synchronization network adapters
Fernando Ejarque [DevOps Member]12 19th November 2021 0 Comments
I have two DMAs installed in a virtual environment. Each DMA has three network adapter configured, one for corporate network, one for acquisition network and one is for sync between DMAs. This thirth network is virtual, is connect internally in the hypervisor, so is faster and has low latency.
How can I configure the DMAs to use this thirth network adaptor for sync purpose between DMAs and how can I check after if it is doing well?
Thanks in advance!
Wouter Demuynck [SLC] [DevOps Advocate]7.03K Posted 22nd November 2021 0 Comments
For communication between DMAs, DataMiner relies on the operating system to route the traffic to the remote DMA. DataMiner is using the IP address of the primary interface (as listed in Cube > System Center > Agents) for the communication.
It’s the operating system which decides which route to take based on available interfaces/subnet masks/routes/metrics. Typically, the source network interface being used will be the network interface which has the matching IP address (same subnet) on the source DMA.
Ive Herreman [SLC] [DevOps Enabler]14.77K Posted 19th November 2021 1 Comment
Hi Fernando,
You can configure which NIC needs to be used on the “synchronization” page of your failover configuration.
You can find some details on this section in the help.
Fernando Ejarque [DevOps Member] Posted new comment 21st November 2021
Fernando Ejarque [DevOps Member] commented 21st November 2021
Hi Ive,
Thanks for the answer but I was talking about the sync between DMAs in a DMS, not between a DMA and its failover.
