How Resource utilization and integration happens in Dataminer
Solved808 views19th July 2023
sangmitra b32 12th July 2023 0 Comments
Let say I have a EC2 based environment, where resource usage costing is increasing. in the EC2 automatically the services are getting monitored to reduce the cost, is there any interface to check the resource which are being utilized. And how do I technically integrate Dataminer to get the work flow.
please help me how Dataminer helps in doing that.
Miguel Barquet [SLC] [DevOps Advocate]1.92K Posted 17th July 2023 0 Comments
Hi Sanmitra,
I suggest you read this article Amazon AWS EC2 - manage compute capacity and cloud applications with DataMiner - DataMiner Dojo
Take a look at the screenshots in the use case Amazon AWS EC2 - manage compute capacity and cloud applications with DataMiner - DataMiner Dojo
There you might find the answers you are looking for.
Regards
