How my low code make it more responsiveness and faster
Solved702 views28th August 2025
Davor Joleski [DevOps Enabler]743 12th February 2025 2 Comments
Hello everyone i have a question, how can i make my low code app pages to be more efficient and be more faster load the tables and visualizations.
i found something in dataminer about lazy loading for tables is  this one of the solutions that helps for the reasons  or is only on Cube
or if it's not is there other ways to improve speed on low code pages for loading the data in visualization and tables and etc..
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2025
Wout Mahieu [SLC] [DevOps Catalyst] commented 12th February 2025
Hi Davor, can you add some more details about the tables that are loading slower than expected? How do the queries look like, is there any data linked from other components, …
The setting you found has no impact on LCA.
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2025
Hi Davor,
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 26th June 2025 0 Comments
Hi Davor,
I noticed that this question has been open for some time now. Do you still need help with this, or have you found the solution in the meantime? If you still need help, could you answer Wout’s question above? Or if you have found the solution, could you post an answer for reference for other users?
