How do we set Cube time to display in 24hr format rather than 12 hour AM/PM?
Solved3.18K views25th June 2023CUBE GUI
Steve Purcell [SLC] [DevOps Advocate]2.69K 23rd June 2023 0 Comments
We have users which would prefer to use 24hr time, however, we could not find a setting which would allow for changing Cube from 12 hour AM/PM format to 24 hour format.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 25th June 2023
bruno santos [SLC] [DevOps Advocate]1.30K Posted 23rd June 2023 0 Comments
It’s linked to your regional settings but you can change it to another zone.
Alternatively, on windows regional settings,  you can customize it individually – below I’ve selected 00:00 time format without AM/PM
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 23rd June 2023 2 Comments
Hi Steve – my cube shows 24h time.  If I’m not mistaken Cube just follows date & time format set on the client machine.  I assume it just shows what is also shown on the task bar.  If that user changes it for his client machine, it will follow in Cube.
Ben Vandenberghe [SLC] [DevOps Advocate] Unselected an answer 25th June 2023
Steve Purcell [SLC] [DevOps Advocate] commented 23rd June 2023
Thanks Ben, that worked, I was looking for a Cube setting…
Ben Vandenberghe [SLC] [DevOps Advocate] commented 23rd June 2023
And apparently there is also a Cube setting, see Bruno his response. I wasn’t aware on the top of my head, but apparently you could also override it rather than change it in Windows.
