How do I display of an Element status in a view?
Solved2.06K views19th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Member]945 8th March 2021 0 Comments
I want to be able to view the status of Element outages in a View without alarm template.
Is there any way to identify manually stopped elements?
A syntax that returns Active/Stop/Pause is desirable.
That distinguishes it from device problems such as timeouts.
Miguel Obregon [SLC] [DevOps Catalyst]23.86K Posted 8th March 2021 1 Comment
Hi Yuki,
Another option for this case could be using listView. For example, if you would like to display the active elements for the view ‘MyView‘, you could define the following data shape in a shape:
This will result in the following overview:
You can find more information about how to use listView shape data in DataMiner Help – ListView.
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Member] commented 9th March 2021
ListView is close to what I’m looking for.
I only want the STATE in this one.
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 8th March 2021 1 Comment
Dear Yuki Arakawa,
If you would like to show stopped or paused elements under a view, you can use the following Shape Data on your Child group:
ChildrenFilter: AlarmSeverity:Undefined
Normally, the following Alarm severities can be used in this syntax:
  • Undefined
  • Normal
  • Warning
  • Minor
  • Major
  • Critical
  • Information
  • Initial
  • Masked
  • Error
  • Notice
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Member] Posted new comment 9th March 2021
Wouldn’t this all be undefined without the use of an alarm?
