How can I transfer a deployed package between DMS systems?
Solved2.34K views26th April 2024#deploy #package #IDP
Kawssar Marzouk [DevOps Advocate]597 17th April 2024 0 Comments
I need some guidance on transferring a deployed package from DMS1 to DMS2. DMS1 is cloud-connected, making it easy to deploy packages from the catalog. However, DMS2 isn't cloud-connected.
I've attempted to copy the protocols individually from the Skyline DataMiner folder --> Protocols of DMS1 and upload them to DMS2. While the protocols are successfully copied, the automation scripts aren't.
Could you advise on the best approach to ensure the automation scripts are also transferred correctly?
Kawssar Marzouk [DevOps Advocate] Selected answer as best 17th April 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 17th April 2024 0 Comments
Hi Kawssar,
In DMS1 you should be able to see the installed package in the folder C:\Skyline DataMiner\AppPackages\Installed\PACKAGE_NAME_guid. Here you should be able to find the dmapp package file. You could copy this dmapp package to DMS2 and install it.
Hope it helps.
Bert Vandenberghe [SLC] [DevOps Enabler] Edited answer 26th April 2024
