Hide/show shape data in Visio. How use it for color channging green/red ( no for alarms color )?
Solved1.73K views18th July 2024
Jaroslaw Burtny [DevOps Member]756 20th March 2024 2 Comments
Hi All
I tried to use the Hide rule as below, but something doesn’t work for two shape data as below on screens:
Hide : <A>-A|Value|[var:MyVar]|=0
Hide : <A>-A|Value|[var:MyVar]|=!0
I would like to use this solution for the MAIN and BACKUP channels. If the active MAIN is visible, the color is green and the second shape data is not visible, and if the BACKUP channel is visible, the color is red and the shape data MAIN is not visible..
I have some problems. Should I use only HIDE for both shape data or rather HIDE and SHOW together for these two shape data ?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] commented 5th June 2024
I noticed that this question has been open for some time now. If this has been resolved in the meantime, could you select the best answer so the question is closed? If none of the answers provided the solution, but you have found it yourself, could you add an answer of your own for the reference of other users?
As this question has now been open for a long time and there has been no further reaction from you, I will now close it. If you still want more information about this, could you post a new question?
Jaroslaw Burtny [DevOps Member]756 Posted 20th March 2024 1 Comment
Hi Miguel.
I deleted SHOW from Parameter
The problem the same.
Br.
Jarek
Toon Casteele [SLC] [DevOps Enabler] commented 21st March 2024
I’m actually not sure what you are trying to compare. The syntax for your Target and your “What” don’t seem valid. https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/miscellaneous/Extended_conditional_shape_manipulation_actions.html
Could also be useful to check out our course on this: https://community.dataminer.services/courses/visio/lessons/shape-conditions/
Jaroslaw Burtny [DevOps Member]756 Posted 20th March 2024 2 Comments
Hi Toon.
Yes, I changed it as below :
How you can see HIDE doesn’t work. You can see two MAIN shape data.
The problem is still there
BR.
Jarek
Jaroslaw Burtny [DevOps Member] Posted new comment 20th March 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 20th March 2024
Hi Jaroslaw,
In your ‘Parameter’ data shape I see the option ‘SHOW’
Can you remove this option and try again?
Jaroslaw Burtny [DevOps Member] commented 20th March 2024
Hi Miguel.
Problem the same.
I sent the sreens as below
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 20th March 2024 1 Comment
A negative condition should be “!=”, not “=!”. Could you try again with this configuration change?
Hi Toon.
I replied below
Jarek
