Help with Accessing Content in DataMiner Backup File After Changing Extension
Solved883 views8th November 2024
Samson Fayoyiwa [DevOps Advocate]536 6th November 2024 7 Comments
Hello community,
Weeks back, I posted here asking how to access the content within a DataMiner backup file. I was advised to change the file extension to .zip, as this should allow me to view the files inside. However, I regret to say that I’ve tried this, and it is not working (please see attached screenshot for reference).
Has anyone else encountered this issue or have suggestions on alternative methods to view the backup contents?
Any guidance would be highly appreciated.
Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th November 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 6th November 2024
Hi Samson,
Can you confirm that you are able to see the file extension? By default, the file extension is hidden.
Samson Fayoyiwa [DevOps Advocate] commented 6th November 2024
Am not sure it is apparent but I assumed any suffix after the dot symbol is what should be changed to the get the desired extension because that was what I tweaked
Hi Samson,
If the file extension is hidden, you are changing the file name. From your screenshot I can see that the bird icon is still displayed. This is the reason I am suspecting that the file extension is hidden.
Thanks, how do I access the extension?
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 6th November 2024
Another option If you have WinRAR installed. Simply right click the file and open with WinRAR. You will then have access to all the files.
Show 2 more comments
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 7th November 2024 1 Comment
Hi Samson,
Just adding an answer here to close this question. As a conclusion, after enabling the visualization of the file extension you were able to see the content of the backup file.
Samson Fayoyiwa [DevOps Advocate] commented 7th November 2024
Hello Miguel,
Exactly, you have summed it up aptly
