GQI Custom Operator – Input parameter from “text input 1”
Solved1.21K views26th March 2025
Stefan Schedletzky [DevOps Advocate]2.76K 25th March 2025 0 Comments
I’m working on a GQI custom operator. But I want to use in the operator a custom text field from the app.
For example “Text input 1” should be passed to the GQI script. But I don’t know how I can retrieve it in the script.
How can I achieve it?
Stefan Schedletzky [DevOps Advocate] Selected answer as best 26th March 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.74K Posted 25th March 2025 0 Comments
Hi Stefan,
As far as I know GQI custom operators only support operations on columns. As a workaround, you could use the concatenate operation to add a column with a custom text:
You can pass the custom text to your custom operator.
In case this workaround does not fit your use case, then you will need to use an ad-hoc data source:
Hope it helps.
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 26th March 2025 1 Comment
Hi Stefan,
Just as an Ad Hoc Data source, a Custom operator can implement the IGQIInputArguments interface in the script. This interface can define which arguments the operator needs to perform its operation. Unfortunately these arguments cannot yet be linked to other data/components in the app when coming from a custom operator. A workaround would be to add the custom operator to an ad hoc data source (as Miguel suggested), which can already have inputs linked to other data.
We have a task on our backlog to implement this feature. We will let you know here when it is ready.
Stefan Schedletzky [DevOps Advocate] Posted new comment 26th March 2025
Stefan Schedletzky [DevOps Advocate] commented 26th March 2025
Thanks, looking forward to it!
