Get HTTPS/TLS info from automation script
Solved1.85K views31st January 2023Automation script security
7
Seppe Dejonckheere [SLC] [DevOps Enabler]2.80K 31st January 2023 0 Comments
I would like to create an automation script that, in a first phase, can give me information about several security settings:
  • HTTPS on Dataminer
  • Client-Server encryption for cassandra/elastic
  • Inter-node encryption for cassandra/elastic
How can I retrieve this information?
Seppe Dejonckheere [SLC] [DevOps Enabler] Selected answer as best 31st January 2023
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K Posted 31st January 2023 0 Comments
I can only help for the first one being HTTPS configuration. For this you have two options IMO:
  1. parse the C:\Skyline DataMiner\MaintenanceSettings.xml file and look for the <HTTPS/> tag. There you will find the attribute "enabled" followed by the FQDN of the system.
  2. Call the IIS manager and get the configuration for the port bindings. I did a quick search and found this method that you could use.
Baptiste Pattyn [SLC] [DevOps Advocate] Answered question 31st January 2023
