Generate Alarms with an Automation Script
Solved1.77K views1st September 2025alarm alarms Automation script automation scripts licenses
Maxime NOEL [DevOps Member]104 3rd April 2025 1 Comment
Hello everyone,
I have created an Automation Script in DataMiner that checks the expiration dates of Nevion Virtuoso MI software licenses.
The script:
  • Identifies licenses that will expire within 50 days.
  • Separates expired licenses from those that are about to expire.
  • Sends an email notification with a list of affected elements.
I would like to know if it’s possible to generate DataMiner alarms based on the results of this script. Specifically:
  1. Can DataMiner create alarms dynamically based on calculated values in an Automation Script?
  2. If not, what is the best way to integrate this logic into DataMiner’s alarm system?
Thanks in advance for your insights!
Best regards,
Maxime
Maxime NOEL [DevOps Member] Selected answer as best 1st September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 3rd April 2025 1 Comment
Hi Maxime,
Assuming that you are retrieving the license information through a connector, I believe the best approach here is to update the connector and implement extra parameters that can be set through the automation script. These parameters can contain the result of your license, and raise the corresponding alarms.
In case you are not able to update the connector, another option could be using element properties. Your automation script could update element properties. These properties can be monitor in an alarm template, and used to raise the corresponding alarms.
Hope it helps.
Alberto De Luca [DevOps Enabler] commented 7th April 2025
Option 1 from Miguel's suggestion is what I'd choose, if viable in the target environment: once the "License Expiry" parameter in the connector is usable in the alarm template, you can define the alarm quite easily and base any subsequent notification on that.
If I recall correctly, the licenses on the Virtuoso MI would be tied to the media functions you need to run on the server – hence having this directly available via the DM protocol could be an advantage if the unit presents this info on the integrated API.
HTH
Bram Devlaminck [SLC] [DevOps Advocate]942 Posted 3rd April 2025 0 Comments
Hi Maxime,
The answer (from Tobe Deprez) on the following DOJO post is probably what you are looking for:
Show message in active alarms using automation script
Hope this helps.
Kind regards,
Bram Devlaminck [SLC] [DevOps Advocate] Answered question 3rd April 2025
