Failover without virtual IP
Solved2.54K views11th July 2023Failover
Bernard Pichot [SLC] [DevOps Advocate]1.43K 23rd September 2021 0 Comments
Hi There,
It's now possible to setup failover with a hostname instead of virtual IP. Does this mean that the two Dataminer agents in failover configuration can be in different IP sub networks ?
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 24th September 2021 0 Comments
Instead of a virtual IP you will have a shared hostname.  This can be done in two ways:
  • Add both IPs to the DNS server with the same hostname, so the client retrieves both IPs when resolving the hostname.
  • Adjust the hosts file on the client PC.  This is done in case there's no DNS server on the network.
You can check the result of the action on the client by executing following action in PowerShell.  The result should show the 2 IPs.
[System.Net.Dns]::GetHostEntry("hostnameGoesHere")
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 24th September 2021
